NTL outputs question
Discussion in 'Cable TV & Virgin Media TV' started by samuraijack, Oct 29, 2003.
  1. samuraijack
    samuraijack
    Hi, I'm really stuck with this issue, any help appreciated!
    I want to get a Panasonic 6 42" (monitor only) and a Jamo DVR50 one box DVD system/speaker package and I want to get NTL (Freeview or Sky not options) as TV source. Reasoning behind Jamo is mainly budget and space constraints.
    I can use component to connect Jamo to screen and NTL picture to screen through RGB Scart or SVHS (I think). How can I get NTL audio though? The Jamo has TV, video and aux phono inputs - is it possible to connect the NTL box to one of them to get TV sound?
  2. jmack
    jmack
    yes alot of ntl boxes have audio out. L and R stereo.
    if not you can buy a scart cable with a breakout L and R audio.
    hope this helps
  3. samuraijack
    samuraijack
    so with either of these options I'd have two cables to connect to the Jamo box for TV audio is that right? Can I plug them into any 2 of the 3 TV, video and Aux inputs or would I need some kind of adaptor to plug both cables into just one of the inputs?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    i have been told the L & R out are dual mono not stereo better off with a breakoutlead.
  5. samuraijack
    samuraijack
    Cool, cheers - I guess that'd mean I wouldn't need to rely on NTL supplying a specific box as well. Would I need an adaptor to make the 2 breakouts into one connection though or can I just use any 2 of the TV, video and aux inputs on the Jamo box?
  6. jmack
    jmack
    horny is this true as i use the 2 audio outputs on mine and my amp shows up as stereo?
    if it is i will get a breakout cable
    cheers
    let me know
  7. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    My NTL box definately output stereo from the phono sockets.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    I think it might only apply to early boxes (the amp will always think its stereo as long as it gets two feeds) I'll ask a mate (works for ntl). This advice was given to me a couple of years ago by another forum member no longer have ntl so cant check my self.
    Might be worth emailing Pace but as there are4 boxes i know of in use (digital) as well as allsorts of analogue!
  9. ledzep100
    ledzep100
    May 7, 2003
    251
    Windsor, UK
    All boxes with 2x phono connections will output stereo audio when the channel is carrying stereo audio. When the content is mono you'll have that on both (dual mono).
    Break out from a scart works the same.
  10. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    I have NTL at the moment.
    For video I use RGB output via an AV SCART cable to a JS box converting RGB to component. The component cable goes to my receiver and then to my screen.
    For audio, the same SCART cable plugs in to the the JS box, which has L&R audio out. The audio out plugs into my receiver which processes the sound.
    There's no problem with the JS conversion box
    Taimur
  11. jmack
    jmack
    taimur
    my setup is same but component goes into iscan ultra.
    will try this way of connecting audio tomorrow to compare with the audio outputs i use on ntl box
