NTL-no outputs for sound to amp-Pls Help!
Discussion in 'Cable TV & Virgin Media TV' started by Elmo76, Jun 28, 2005.
  1. Elmo76
    Elmo76
    I've had NTL installed as I can't have Sky at the flat I'm in. I've been given a Samsung set-top box but it has no means of carrying sound from it to my amp. I've been informed by someone at NTL that this may be the case for all the boxes.
    Can you please, please tell me if there is any way of carrying sound from NTL to my amp? :lease:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Yep there are a few NTL boxes that do not have dedicated audio outputs.
    I know there is always pressure to cut costs but not having audio outputs seems a short sighted approach or perhaps they honestly believe that their customers are not the type to have dedicated amps etc.
    You can buy a scart cable which includes twin RCA phonos for sending the audio to an amp, not too expensive.
  3. Elmo76
    Elmo76
    Starburst, thanks for your response.
    Excuse my ignorance though, but the set top box only has one scart so surely I'd need that to go from the box to the tv, making a second scart impossible?
    Unless, can I just have the one scart going from the set-top box to the amp, but what about the picture?!!!
  4. mattross
    mattross
    Oct 23, 2004
    257
    +6
    I thought all NTL STBs had 2 SCARTs? All the ones I've had have 2 [all Pace]. I use the primary one [RGB] to my Quintro+, and the secondary to my AV amp.
  5. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Only one scart?
    Blimey that's severe penny pinching:(
    The scart to scart cable has additional cables which break out from the end which fits in the STB this sending the video/audio to the TV as well as seperate cables (RCA phonos) for audio to use with an amp.
