NTL internet lost IP address
Discussion in 'Cable TV & Virgin Media TV' started by (GTV)Chris, Jul 10, 2003.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Everything on my pc was fine and dandy....then I asked to upgrade my 600 line to a 1mb line,
    When I got homa and booted up my Win2000 syayten it sat on detecting network settings and when fully booted it had somehow lost my IP TCP settings and I cannot access the internet at all.
    Called NTL but they couldn't sort it.
    I connect Via a modem and ethernet cable. ANy ideas what has happened????
    My network adapter is Realtek built into the motherboard.
    Any help greatly apprecited.
    Ta
    Chris
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Power Off the Broadband modem and disconnect the coax line from the back for a few hours (at least 2) - this will reset the MAC address and might sort out your problems.
