NTL fm connection cable charges
Discussion in 'Cable TV & Virgin Media TV' started by zoolap, Jun 10, 2002.
  1. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +8
    Apparently to get an NTL fm connection cable you have to call them out and pay about £50. Is there anywhere on-line you can get the correct cable + connectors? What should you specify?
  2. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    I am assuming that you have an NTL analoge setup here.
    I had NTL analogue because even though I had Sky, I had to have the 'starter package' from NTL in order to have a cable modem. As such, the NTL STB is just providing a signal to the video so it can set the clock.
    When I decided to hook up the radio link, I looked at the connector on the wall box and just took the lead that was connected to the STB, plugged the same lead into the other connector on the wall box and put the terminator that was on the radio connector onto the TV output.
    If you know somewhere that does cables, then you could take the cable you are currently using for the STB to them so they can copy it.
  3. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
