ntl dns error
Discussion in 'Xbox Forums' started by ford fairlane, Jan 2, 2007.
  1. ford fairlane
    ford fairlane
    hi
    having a problem connecting to xbox live as well as the net can only use one or the other
    i am with ntl and using a netgear dg834pn wireless router but am using the wired option i know its an adsl router but didnt think it would make a difference as i am using the wired option
    what happens is if i connect to the net i keep getting a dns error on live but the connection is fine and the ip is fine
    i have looked about on the ntl site but am unable to sort out the problem
    would i be better getting a new router and if so what would be the best option
    thanks
  2. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
    You cannot use that router with NTL, sorry
  3. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    Ditto, look for a broadband router, not an ADSL router.
