NTL Digital - TV picture is zoomed
Discussion in 'Cable TV & Virgin Media TV' started by Bursar, Nov 25, 2003.
  1. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    Just had it installed today, and I've noticed that the TV image is zoomed in.
    I'm watching The Weakest Link at the moment, and the money bar on the left of the screen is fully visible, and has some space on the left of it.
    When I watch it through the NTL box (on the AV2 channel of my TV) the money bar is up against the left hand, and bits of it are chopped off.
    I'm figuring it's a problem with the configuration of the box, because the picture is fine if I watch the analogue signal.
    Anyone got any ideas as to what I can do? Or do I need to get NTL out to fiddle with the box?
  2. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    D'oh, not to worry :) I called NTL, and they told me to put the STB into 16:9 mode rather than the default of 4:3 P&S.
    If I'd have gotten a manual with the box, I'd have known that...
  3. jem
    jem
    Sep 24, 2002
    527
    +7
    The RGB scart is usually AV1 - is AV2 on your TV also RGB or are you not using RGB?
  4. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    This might be daft, but how can I tell?
    The VCR is on AV1, the NTL box on AV2.
    When I put the NTL box into RGB mode (as opposed to composite) the picture looks exactly the same.
    I've taped from both the analogue and digital sources, and they're both fine.
  5. jem
    jem
    Sep 24, 2002
    527
    +7
    Most TVs have only one RGB scart - a few have two but not that many. Your TV manual should tell you.
    If, as I suspect, AV2 is not RGB and your NTL box is always into AV2 then you would notice no difference when you put the NTL box into RGB as opposed to composite. Swap your NTL box onto AV1 and your VCR onto AV2 and you should see a difference.
    Connections should be as follows using scart;
    VCR (TV) to NTL VCR
    NTL TV to AV1 on TV
  6. Kevo
    Kevo
    Aug 23, 2001
    5,354
    Manchester
    +144
    No need to connect your VCR to the TV via SCART.
    Just connect it to NTL (VCR) and you will be able to record from NTL and playback through NTL on AV1.
    This will free up AV2 on your TV.
  7. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    SCART connections on this TV aren't a problem. There are 3 on the back, and a composite input on the front.
    I also need to hook up a DVD player as well, but I'm thinking about replacing the VCR with a VCR/DVD combo to make life easier.
    I'll have a play with the connections though, and see if it makes any difference to the image (which, IMHO is fine as it is).
  8. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Regardless of whether you need the scart sockets or not, you're still better off plugging the VCR into the NTL box.
    Unless you need to record terrestrial TV.
  9. Kevo
    Kevo
    Aug 23, 2001
    5,354
    Manchester
    +144
    If you do get a combi then I would imagine that the SCART on it outputs RGB for DVD and composite for VHS.
    Again the NTL vcr scart would be ideal as it has RGB in as well as composite in/out.
  10. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    That's the thing. It would be nice to be able to record one channel whilst we watch another.
    As things stand at the moment, I can quite happily record one analogue channel whilst watching another, or the digibox channel.
    Or I can record the NTL feed whilst whatching an analogue channel.
    That isn't something that I want to give up.
  11. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    If you put an RF cable into the VCR as well as connecting to the NTL box, you'll still be able to do so.
    I think.
  12. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    Cheers for the tips, I'll have a play with the box and see what happens :)
