NTL Digital Picture Quality
Discussion in 'Cable TV & Virgin Media TV' started by chiwan, Jun 21, 2002.
  1. chiwan
    chiwan
    To all you NTL digital users
    Have you noticed any degradation in picture quality over the past 2 days.
    I was watching Big Brother on Channel 4 the other night and the picture suddenly went very grainy and there was colour bleed especially with red. Thought this was confined to Channel 4 so tried BBC1. Again the picture was grainy and there was a lot of picture noise on backgrounds.
    Tried playing a DVD and then my VCR which were both okay.
    I know NTL have introduced various new channels on to 800 - 900 channel numbers so are they lowering the bit-rate on their broadcasts?
    Is there a way of finding out the bit-rate etc
  2. stranger
    stranger
    try 'phoning customer services and insist on finding out, you're paying for it.
  3. AndyFox
    AndyFox
    Yep from the installation /setup menu which the engineer uses to code the box on site.
    Soft Reset the box then a pair of keys held together ( don't recall which ones ) take you into the menu.
    Andy
  4. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    its the up and down buttons.
    turn off, then turn on holding the two buttons on the decoder.
    E4 has always been pretty ****ty on the bitrate.
