ntl Digital / Analog splitting..
Discussion in 'Cable TV & Virgin Media TV' started by CarlChip, Sep 11, 2004.
  1. CarlChip
    CarlChip
    Aplogies in advance because I'm sure this question has been asked a million times before...
    can anyone tell me how to split the digital and analog signals i receive from ntl?
    The digital tv signal i want to view on my main TV whilst the analog signals i want to route to other tv's in the house.
    If i connect the incoming signal directly into the main tv, i can receive the analog channels in the normal way and route them to the other tv's in the house - no probs there!.
    the problems arise when i try to 'split' the signals using either a 'Y' piece type splitter or a 4 way amplifier.
    With the 'y' piece splitter, the digital signal does not appear at all.
    With the 4 way amp, the signals recieved are rubbish (possibly over amplified?).
    ntl have changed the STB. They also tell me that the signal strength is very low - has this got anything to do with it?
    I had none of these problems before when i was on the analog ntl service.
    Yours in despair,
    Carl.
