NTL Digibox - Extending Cable length??
Discussion in 'Cable TV & Virgin Media TV' started by dean randle, Oct 15, 2004.
  1. dean randle
    dean randle
    Jan 9, 2003
    156
    UK (Bromley)
    +6
    After unsuccessfully searching the forums, I wonder if anyone can help me? I have an NTL cable tv digibox, and it is connected to a cable which runs into a box on the external wall. I want to extend this cable to run it either to the opposite side of the room or into another room completely. I have a video-sender, but unfortunately the signals used by ntl don't work on them.
    All pointers will be greatfully received.
    Dean.
  2. jmack
    jmack
    i extended my ntl cable ages ago from wall to box just normal coaxial with screw on ends. about £3 in all from maplins.
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,264
    Manchester
    +756
    You can plug a longer coaxial cable cable into your wall socket. Use high quality 75-ohm cable ; double-screened is best.
    I would advise against extending your existing cable (adds too much loss as well as less reliable).
    It should need an F-type (male) connector at each end - available from Maplins, B & Q and satellite shops.
    Chris Muriel, Manchester
  4. MikeHarrison
    MikeHarrison
    Use satellite type cable (CT100) , not TV aerial cable.
  5. dean randle
    dean randle
    Jan 9, 2003
    156
    UK (Bromley)
    +6
    Thanks for the help guys, now watching my tv after doing the necessary work!
    Went to maplins and got the bits, all fairly easy afterall
    Cheers,
    Dean.
