NTL Digi Box just says 'tune' - Any Ideas?
Discussion in 'Cable TV & Virgin Media TV' started by Ian Carter, May 19, 2004.
  1. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    As title really. Just got a new anp and was re-arranging the equipment. Plugged NTL box back in and all I get is 'tune' in the display. Do I need to call an engineer?
  2. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    Do the channel up and down buttons on the front of the box change the channel to numbers between 20-72. I seem to remember seeing tune on mine when the engineer was changing the default channel for RF.
  3. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    None of the buttons seem to do anything amymore!
  4. Tides2002
    Tides2002
    Jul 5, 2002
    141
    +12
    What is being displayed on the TV? I can think of two possibilities, the STB maybe trying to upgrade its software and failing in which case it will come back to life after about 90 minuets. The second is the tuner is dead, how hot is the left hand side of the box? If it’s around room temperature then the problem is defiantly with the tuner.
  5. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    Thanks for the reply. I left it on all night and it still says tune this morning. STB is very hot to touch (as always) Just a blue screen on the telly when av1 is selected - but can view all the terrestrial channels via the box pass through. Box was 'upgraded' to the latest look overnight last week sometime.
  6. Tides2002
    Tides2002
    Jul 5, 2002
    141
    +12
    Switch the box off, and take the viewing card out of its slot. Take a look at the chip on the card don’t be surprised to see the plastic around it has melted and brown in colour!
  7. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    Yeah - its a bit brown - no too bad though. Should I be loking for anything in particular?
  8. Ian Carter
    Ian Carter
    Apr 4, 2002
    763
    Swindon, Wilts
    +3
    Just phoned NTL - very helpful actually. Told me to do a 'Hard Reboot' - which was hold down 'Down Arrow' on front of STB and plug in to mains at same time. That has cured my problem and I now have a fully functioning STB again.
    Thanks for your help Tides2002
