NTL DI4000 and video sender
Discussion in 'Cable TV & Virgin Media TV' started by Gee, Sep 16, 2004.
  1. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Hi all,
    Does anyone know of a video sender that is compatible with the remote control for the NTL DI4000 box?
    Thanks,
  2. Nelviticus
    Nelviticus
    Jun 21, 2003
    474
    Hitchin
    +69
  3. Te Bheag
    Te Bheag
    Sep 16, 2004
    459
    Wolverhampton
    +16
    Hi, my first post to the forum, hope I've done it right...
    If you are looking for one - Argos have been selling Digisender Gold units for about £59. Look in their 'catalogue clearance' section in-store. They have an old item number, but are identical to the current catalogue item, which is selling at about £100.
    The number is 048/0424. They are available at Argos Extra stores.
    They work with my Telewest Pace box perfectly. Hope that helps. :)
    Alastair
  4. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Nelviticus,
    Thanks for the info and the link. Things are a little clearer now.
    Alistair,
    Good work on your first post! :thumbsup: I'll check out my local argos to see if they have got stock.
    Thanks again!
  5. Te Bheag
    Te Bheag
    Sep 16, 2004
    459
    Wolverhampton
    +16
    Sometimes you can 'click & collect', but I've tried this and no luck... Remember it need to be an Argos Extra store - good luck! They are really easy to set up and you can link up to four components into it. I also got (from Littlewoods Extra) a remote to control the TV, DVD and cable from upstairs, this also works well for a tenner, if it is a little fiddly to use.
    Alastair
