ntl cable picture quality
Discussion in 'Cable TV & Virgin Media TV' started by luckydip, Aug 24, 2003.
  1. luckydip
    luckydip
    Can folks please tell me what the picture quality is like on their respective plasmas when using a ntl cable box. The reason being that I watch a lot of sports (sky) and wanted to get a display that could handle this.
    lucky
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Mine is perfect, nothing that you could question.
  3. luckydip
    luckydip
    Mate, can you tell me what plasma you are using?
  4. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Panny series 5 42 inch.
    Neil.
  5. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Hello Neil... Could you please let me know how you connect your NTL STB to the screen...
  6. mrv
    mrv
    Feb 3, 2003
    153
    Portsmouth, England
    No complaints on mine either and I watch a lot of footie.
    Panny 5 series 37 inch connected to VGA via a JS RGB->VGA box.
    Mike
  7. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    I've used the following methods that are all perfect:
    NTL - > Panny Tuner box
    NTL -> Panny SCART board
    NTL -> JS Plasma VGA -> VGA port
    all look perfect.
    Neil.
  8. jmack
    jmack
    was that the scart board you bought off me?
    how is it? was it easy to ge working ?
    how does the picture compare with a rgb to vga converter?
    cheers neil
  9. kevshed
    kevshed
    Oct 30, 2002
    1,246
    48
    bournemouth
    +98
    Im using NTL Digital connected as below to a 42" Panny 3 Series... quality is as good as i believe you can get.... with this kit combo
    NTL Digi - RGB Scart -> Tivo
    Tivo -> RGB->VGA Converter (JSim)
    Converter -> Dsub on plasma...
    Pretty good picutre overall.. some greyscale issues and slight bleed on reds, but i put that down to the dated plasma :) Latest models should be better.
    Cheers,
    Kev
  10. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    jmack,
    Yup :D
    Plug and play.
    i finally hooked it up about a month ago :D
    Picture is better than an RGB to VGA convertor, the rgb2vga suffers on skin tones compared to the direct in.
    Now deciding on what to do with the tuner box :D
    Neil.
  11. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    Don't know about NTL digital, but if it's NTL analogue then it'll look crap on any plasma......or any 14" CRT portable for that matter! ;)
