NTL cable modem and router help
Discussion in 'Cable TV & Virgin Media TV' started by fufna, Aug 11, 2003.
  1. fufna
    fufna
    I'm connecting a cable compatible router to my system (PC connected via Xover ethernet into an ethernet to USB adaptor.
    It works like a dream as it is (without a router) but I need the router to connect my Xbox and PS2
    I can't even connect to the router on it's given address when I try to set it up
    Any ideas?
    And please don't mention removing the USB adaptor because I know of 3 people with the same setup who use theirs fine.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    What router is it and why use USB I run a linksys 4 port DSL router with no problems but you do have to turn them all on in the correct order or it dont work!!!!
    Why not use ethernet much better network connection USB can only do networking ethernet was designed for it!!!
    Which ntl modem is it STB or Terayon or ntl 100???
  3. fufna
    fufna
    using the USB dongle due to no ethernet adaptor or spare slot.
    It's a linksys etherfast 4 port dsl/cable router
    It's an NTL STB
    I'm wondering if the crossover adaptor has something to do with it.... not sure why it has to have one to worl... but thats the way it is!!
    I'm going to log into the chat room now (I know you spend a little time in there Dragon!!)
    be obliged if you could try and help me in there
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Never used the STB Modem only the stand alone one so no idea mate will log into chat now though!
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    So any joy????
    Turn Router on first then modem set mine up tonight!!!
