NTL Broadband+console questions
Discussion in 'Networking & NAS' started by colesy, Mar 12, 2003.
  1. colesy
    colesy
    Dec 28, 2001
    721
    +16
    NTl have a subscription for 600k BB and the necessary bits to allow PC connection at the same time. All sounds very nice, but for a newbie I have some questions.
    1) Is there a major difference for Xbox live between 600K and 1MBS?
    2)Is it worth them supplying the bits (router I think it's called) for 29.99 per month as opposed to 24.99 per month just for the 600k BB?
    3)Should I just go for 600K and buy a router through my local pc dealer?
    Cheers in advance
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    For hosting games the 1M will make it better, but for just playing it will make very little difference.
    Neil.
  3. colesy
    colesy
    Dec 28, 2001
    721
    +16
    Cheers for the reply.
    I maynot be hosting games...I have no friends :(
  4. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    at least he's honest!:D we'll be your friends!:rotfl: :rolleyes:
    I'm in the same position I would like BB to hook up the PC and gamcube, NTL are currently supplying the modem for free I understand. NTL connection is already in place but not in use. Would it be a case of using the one modem to for both PC and console (gamecube requires BB modem with ethernet port)? and seeing as its cable i take it it would make no difference to the phone line?
    sorry for the dumb questions I'm still a dial up user!:(
  5. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    On your 2nd point. £5/month extra for thier router = £5*12=£60/year. You can you buy a router for less than this and it will last longer than a year
    it swings and roundabouts. you're basically renting the router which includes maintenance on the box if it should fail. A one off purchase of a router (say the netgear RP614) is £50 and I would it expect to last more than a year without fault
  6. mr_fantazmo
    mr_fantazmo
    The extra 5 Quid a month is for ntl customer service as well, if you have a problem then they will try and help you out! Whereas if you have another non ntl router they won't!!
    Makes no odd's as you can't get through anyway!! :D
  7. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    isn't that an oxymoron :devil:
  8. colesy
    colesy
    Dec 28, 2001
    721
    +16
    I thought NTL customer service was bad......put me in a difficult position, as my BT line is not capable of BB...yet.
    I will be using my Xbox downstairs, but my PC is upstairs.....
    so I think I will have to get a VERY long ethernet cable and run it loose up the stairs.
    !mbs sound good to me, so I can host. I am useless on games so I expect my bum to be kicked.
    I will probably purchase the netgear as per graham's recommendation, that is if it is user friendly and works with NTL.
    What do you think???
  9. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    I wouldn't say I recommended it:nono:, I just did a quick search to give a reference price point. I have seen threads on here discussing which router is best - do a search. There is LinkSys who NTL recommend, NetGear as stated, D-Link
    I too have my PC upstairs (and at the back of the house). My xbox will be in my cinema room downstairs and at the front.
    I hope they will lay the cable where I want ie upstairs near my PC. I'm considering getting a Wi-Fi connection down to the xbox (and maybe my PS2 when they get thier act together). Going wifi will give me the advantage of surfing on my laptop in the living room/kitchen too even though it has a built in ethernet port for upstairs. I already have a 4-port hub upstairs so its all cabled up - I just need to switch the hub for a router
  10. Sinzer
    Sinzer
    May 25, 2002
    5,794
    +1,108
    Netgear is great, I am a big fan of theirs :)
  11. colesy
    colesy
    Dec 28, 2001
    721
    +16
    Sorry Graham about hat statement!!
    I have been doing a bit of research for a few weeks now, but I seem to be geting more and more confused
    :eek:
    I thought life was supposed to get easier the older you got..lol
    Maybe I'll ask my 13 year old nephew tosort it out for me :rotfl:
  12. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Bit of a newbie in regard to BB. The modem is arriving Friday connections shouldn't be a prob but I was told any extensions from the signal coming in will also carry the BB signal, hence there are two "splitter's" (for upstairs and in the living room)so as two divide the signal into A: the telephone connection and B: the BB signal, so I assume my PC can connect upstairs into the supplied external modem and my PS2 (when it goes online) can connect in my living room?
    Is this correct ???:confused: :confused:
    Matt
  13. colesy
    colesy
    Dec 28, 2001
    721
    +16
    Malone,
    I think you are spot on. I don't think you will be able to use the console and the PC at the same though.
    If I am wrong, I'm sure these guys will tell me.
    cheers
