NTL box
Discussion in 'Cable TV & Virgin Media TV' started by jonhaff, Jun 13, 2005.
  1. jonhaff
    jonhaff
    Firstly sorry if this is wrong forum for this but i couldn't see one for ntl.
    Anyway Ive got a Sony HDD/DVD recorder x510 and was wondering if anyone knew a way to get the ntl box to change channel so you can record different programmes. Not sure if you have same problem with Sky box but with the ntl one you can only record on the currently selected channel and the timer on the Sony doesn't let you change channel .
    Just wondering if its possible.
  2. degringo
    degringo
    Hi, Not possible sorry.
    Check out www.ntlhell.co.uk for more help on ntl systems
    Richard
  3. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    Only way round it is to use the 'Reminder' feature on th eNTL boc to auto change the channel, not ideal I know.
