NTL box - upgrade possible?
Discussion in 'Cable TV & Virgin Media TV' started by harrison99, Nov 26, 2004.
  1. harrison99
    harrison99
    I have an NTL cable box (Samsung). This has a scart connection and does not have separate audio outputs. Is it possible to buy a box which has component video outputs and can be fed into an AV amp?
    Many thanks
  2. Techno
    Techno
    Nov 20, 2003
    312
    Think you'd probably need an RGB to component converter such as the JS one I have for taking SKY+ to plasma via Amp. It has the benefit of seperating the audio (I don't use it cos SKY+ has digital out for the amp).
