NTL Box RGB AND being able to video stuff?
Discussion in 'Cable TV & Virgin Media TV' started by clived, May 27, 2003.
  1. clived
    clived
    Jan 4, 2002
    265
    Hertfordshire
    +5
    I'm currently running my NTL box through my Denon AVC-A1SR into the TV and into the video. However, planning an upgrade to Plasma, so will be wanting to use the RGB output on the NTL box.
    Does anyone know if switching to RGB disables the composite output on the second Scart? (Yes, I know I could try it, but you know how it is - wires, furniture etc. etc.! :blush: )
    Thanks, Clive
  2. davepop
    davepop
    Oct 14, 2002
    49
    On the M1
    I think switching it to RGB will do this on both scart sockets. Although the second scart is slightly different. They are labled up as TV and Video. If you have the video socket connected to your TV and you lock some TV channels they will still show up, but that is a software thing.
  3. phenom2003
    phenom2003
    You can use RGB through scart 1 and scart 2 still outputs composite, as scart 1 can output RGB and composite, while scart 2 outputs only composite.
  4. clived
    clived
    Jan 4, 2002
    265
    Hertfordshire
    +5
    Thank you very much guys.
