NTL and Telewest Broadband
shahedz
Joined
Apr 26, 2005
Messages
11,736
Reaction score
2,658
Points
2,367
2 freinds of mine need wireless Modems Routers (like the Netgear 834G)
does nayone from past expereince knwo if there are are any models that are not compatible with NTL and Telewest Broadband?? also what does every one recommend? i reall liek the NETGEAR 834G becasue of ease of use. should i go for those again? or do you recommened something else?
brilliant!! i'm just going to get on off the shelf in PC world , i was a bit worried because i read somewhere that certain routers wont work on NTL or Telewest but maybe thats just a myth!!
Both Belkin and D-link have worked fine with NTL here,
Dave
I've got a Linksys one and it works great. Have a butchers at this site for some ideas and what will and won't work. As long as you stick to the broadband routers instead of the ADSL ones, you should be fine. I got my Linksys from them, not the cheapest, but still a good price :smashin:
Andy
cheers for the link Andy , there was actually a Belkin one i was thinking of getting which has a free wifi dongle with it so glad its been tried and tested by you Dave
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
