NTL 4001 which remote
Discussion in 'Cable TV & Virgin Media TV' started by lordbilly, Feb 6, 2003.
  1. lordbilly
    lordbilly
    Jan 23, 2003
    189
    Lincolnshire
    +16
    HI, I'v got the NTLDi4001 STB and was wondering which universal remote would be best for it.Read the write up on www.lektropacks.co.uk and they suggest the only remote that works for cable is the kameleon 6. Is this true? If not what is a cheaper alternative. Any input would be helpful.
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,648
    UK
    +112
    most learning remotes that support RC5 will be ok with the 4000 box (as opposed to the 1000 and 2000 series)
    There are some issues though - check out www.redremote.co.uk for more info...
    JJ
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,648
    UK
    +112
  4. steev
    steev
    Oct 22, 2001
    233
    16
    Beds, UK
    I've got a One for All 6 that does my NTL 4001 box as well as everything else. Excellent bit of kit for the money. Should be about 20 quid.
    Ooh, 100th post!
