D
Duffers0
Hi all
Just a quicky question.
My current PC is dying BSOD all over the place and random. Memory test fails but mem modules fine in my other machine............ Anyway my point
Thinking of buying a new PC that will probably have Vista and need to pull files off my old SATA drive in dying machine. Are the harddrive file structures the same on Vista and XP ?? If I mount the old SATA drive (XP format)should I be able to read the files OK on the Vista machine.
Think it should be OK but wanted to check
