NS76H -- How 2 Hack -- ?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by craige4u, May 8, 2007.
  1. craige4u
    craige4u
    Mar 18, 2007
    56
    Heys,
    I wana buy Sony DVP-NS76H, and as i researched it cannot be hacked via its own supplied universal remote....
    I want to know if it can be hacked with any other sony universal remote ?
    Also, any other way tht dont require an universal remote/PDA/Irda Port on comp. ?
    Also, provide an reputed/working link of any hack, as most hacks seems not to be working properly....
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
  3. craige4u
    craige4u
    Mar 18, 2007
    56
    Well,
    As per the link the first hack:
    HI , I CAN CONFIRM THIS PLAYER IS AS EASY AS 1.2.3.4.5. I HAVE JUST DONE MINE !! -WITH THE USUAL SONY REMOTE CONTROL HACK ,JUST PROGRAM A ONE FOR ALL 4 .THE SAME AS ANY OTHER PLAYER HACK WITH DVP-NS IN FRONT OF IT ;
    THEN TURN DVD PLAYER OFF ( STANDBY ) POINT AND PRESS 1.2.3.4.5.... SUCCESS SCROLLS ALONG ...MULTI-REGION IN SECONDS ! ALL DONE .
    Does it require One for all remote ?
    Second hack, requires symbian based mobile - which i dont have.
    Third hack, requires kameleon 1 for All remote control - Not available where i live neither wana order jus 2 hack...
    If i got any of the hacks wrong - tell me plz...
  4. Dr Zaius
    Dr Zaius
    Feb 12, 2006
    139
    +16
  5. ref
    ref
    What are you talking about? "the usual sony remote control hack? what is it?
    Because 12345 does not seem to work for me!
  6. Justin@UH
    [email protected]
    Feb 21, 2002
    2,194
    63
    Location location location
    +94
    Hes refering to the link in this very thread, or you can read the "looking for a hack - start here" sticky at the top of the forum where the general sony hacks are.
    You cannot hack a Sony with its own remote.
  7. ns78h
    ns78h
    If you have a palm / PDA with IR try downloading a remote control app (novii has a demo version)
    You then need to program 5 buttons with the following hex values:
    Button name-1
    0000 0068 0000 0015 0060 0018 0030 0018 0030 0018 0030 0018 0030 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01AE
    Button name-2
    0000 0068 0000 0015 0060 0018 0030 0018 0018 0018 0030 0018 0018 0018
    0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01F6
    Button name-3
    0000 0068 0000 0015 0060 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01F6
    Button name-4
    0000 0068 0000 0015 0060 0018 0030 0018 0030 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01C6
    Button name-5
    0000 0068 0000 0015 0060 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 020E
    Then with the player off (standby) press the 5 buttons in turn - you will see 'SUCCESS' scroll accross the display...
  8. Umster
    Umster
    Jan 3, 2005
    234
    The World is my oyster!
    +6
    Once you have pressed 1,2,3,4,5
    Is it totally multiregion automatically... I.e I don't have to use that remote again for
    press 1- region 1
    press 2. region 2
    etc...
