Now I need BFD help ?
Discussion in 'Subwoofers' started by karkus30, Aug 3, 2004.
  1. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Its probably been answered before....but:
    Now I own a BFD (he says with the authority of one used to handling acronymns and initialisation). I need cables (so I have asked Mr Grant for help), any thoughts. Its all about the XLRs.
    Where the do I start. Which exact sine wave freq. should I download or should I just use the VDE frequency sweep, then what?
    Also posted in SVS set up help thread
  2. recruit
    recruit
    Hi Karkus30,
    Try this link this should help you out, it will be alot of trial and error :eek:
    www.snapbug.ws/bfd.htm
    Loads of tweaking i think :D
    John
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    You may well be better off using the TRS connectors rather than the XLRs if that's any help. You may well introduce hum by mixing balanced and unbalanced connections.
    Havn't got one myself yet so can't help otherwise though. :)
  4. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Ah Ha, thanks, thats just what I needed.
  5. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    It gives the option of wiring pins 2&3 together for unbalanced use. By TRS I think you mean the standard guitar jack plugs?
    You should buy one. Its a bargain for £90.00. Just so techie.
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I've posted the reasoning in your thread in the cabling section which you've probably already found by now.
    I've got a bit of cash lying around at the moment despite having just ordered a Humax box. Let me know how you get on and I'll seriously consider it, I do love being techie but think I might be better off upgrading my Denon 1802 instead. Decisions :(
  7. simonthepieman
    simonthepieman
    Mar 5, 2003
    269
    yorkshire
    +12
    I used the jack plug like a guitar plug
    Mark Grant made me a rca to jack plug sub cables
    This is the best way,unless you are a pro user
  8. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,686
    Newbury
    +218
    yep 1/4" jack to phono plug works a treat.
    when it comes to setup, i personally find that sweeps aren't that useful, except for a final ear-test at the listening position when you are finished calibrating. if you are quick to detect a peak and trough and remember the frequency displayed on your TV at the time, then you are probably on to a reasonable start.
    what is perhaps more useful is the excel spreadsheet and then obtaining several fixed frequencies which you play one at a time and then note the SPL on your Radioshack SPL meter. The frequencies you most need are 20, 25, 32, 40, 50, 63, 71, 80hz. The spreadsheet compensates for inaccuracies in the SPL meter and gives you a rough idea of your room response at the meter's position. Yes this does take time, but its cheaper than buying real time analysis software! Most people just want to remove the larger peaks and troughs with their BFD, not get a ruler flat graph.
    might be worth giving your sweeps a try first - do get an SPL meter though, if you dont already have one, but remember that what it reads at certain frequencies is not always correct. the snapbug site should talk you thru that.
    as always, if it sounds right to you, it probably is!
  9. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    On a slight side note, I've just ordered the new Radio Shack SPL meter. Has anyone had any luck finding new calibration settings for it? It can't be the same as the old one.
    Even without the snapbug site it can be useful to produce your own frequency response. I did some for the Budget Sub Test thread which compared all the subs.
  10. Stone Free
    Stone Free
    Jun 13, 2001
    871
    28
    London
    +28
    Where did you get it?
    I have heard in previous posts that you can get it from Keene, but it is not showing the new part number OME33-4050
  11. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Mark Grant will modify my existing sub cable with a TRS plug on one end. Then make me a seperate shorter cable with the same config.
    The snapbug site is really helpful, I quick read was all I needed (just need the cables to try it). I have an SPL meter, I just need to download a few of the frequencies and burn them to disc. I did download everything from 20 to 100 in 5K steps, but there are a few specific frequencies by the look of things.
  12. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Easiest thing is just to download a tone generator. There's quite a few described in some of the DIY threads, assuming your PC is connected to your hifi of course.
