Novice needs your help!
Discussion in 'Home Cinema Buying & Building' started by TheWhiteHouse, Oct 18, 2005.
  1. TheWhiteHouse
    TheWhiteHouse
    Sep 18, 2005
    56
    New to this game but I am looking to set up a home cinema system in the house we've just moved into. Will be getting either a projector or a 32" LCD tv (depending on which fits best) and need a sound system to complement it.
    Have a budget of around £1700 for the lot, so about £400-700 on dvd,amp,speakers. Prefer an all in one though will consider seperates if you get better value/quality. Have been looking at the Denon 500SD. Speakers will be wall mounted. Decent quality and a degree of futureproof connectors is required. Any suggestions would be welcome so I can go try some out.
    Cheers all.
