novice needs help
Discussion in 'Blu-ray & DVD Players & Recorders' started by colibun, Sep 10, 2004.
  1. colibun
    colibun
    I have just bought a new tv and dvd recorder can I use the red/yellow/white audio video cables for the green/blue/red component terminals?
  2. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Short answer - No.
    The RGB are video-components. They need audio also - red and white like hi-fi connections..
    The red/yellow/white are Right audio, Composite video, Left audio in that order. They would connect to similarly coloured terminals on the TV (I doubt if it has them at the back, maybe at the front mainly intended for video camera or digital camera connection).
    You should connect using scarts and use RGB mode if available, then s-video, then composite in that order for quality. Your DVD recorder manual shuld be quite explicit about the connecting options. All you have to do is make sure the signal types match.
    It is no good feeding an RGB signal from the DVD to a TV scart which cannot accept RGB. The TV manual should tell you which scart will accept what.
  3. colibun
    colibun
    what I was meaning was are all the cables the same internaly so that I can connect blue to blue,green to green and red to red
  4. sweat100
    sweat100
    Yes you can, I am using the same thing now. Cant afford to spend so much on a component cable. I think the quality difference is marginal on my CRT TV. As all are the same wire tpe, no problems so far. :thumbsup:
  5. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    I guess you got my PM reply which agreed with the above.
