novice help! pls
Discussion in 'Projectors, Screens & Video Processors' started by drgonzo, Nov 7, 2003.
  1. drgonzo
    drgonzo
    Apr 11, 2003
    28
    please could you help? I have been a fan of this site for about 6 months and have read many posts which have spurred me on to buy a projector but need some final advice before buying, my budget is limited to about 1000 pounds to buy a Panasonic PT-AE200 is this the right choice for my budget ? and cables and anything else I would need. I need some advice on connecting my pc and A/V equipment together for the best results, what will I need, I would like to watch DVDs TV occasionally and use the pc as well, I am a real novice so please excuse if I have missed any vital info! also the room is all white at the moment will i need to decorate it to get the best results?
    PANASONIC PT-AE200
    HCPC.
    DVD
    GEFORCE3 Ti500.... Svideo DV-I VGA
    CREATIVE EXTIGY SOUND CARD
    CREATIVE INSPIRE 5.1
    VCR AIWA FX7700
    DVD LG DVD-3350E
    NTL PACE DIGIBOX DI400-N
    WATCH TV DVD
    USE PC FOR DVD AND SURFING
    many thanks in advance:smashin
  2. Kramer
    Kramer
    Hi drgonzo,
    The AE200 @ £700 approx is good value & an excellent entry to front projection. The remaining £300 should get you the required cabling, screen etc..
    If going down the HCPC route, a Radeon based graphics card is recommended.
    Also consider a good progressive scan DVD player (the DVD Player forum is worth a visit!).
    To better the AE200 you'll really need to stretch your buget a wee bit - Z1, Z2, AE300 etc...
    Lots of help/advice available here in many fora (HCPCs, DVD Players etc.).
    Best of luck ;)
  3. drgonzo
    drgonzo
    Apr 11, 2003
    28
    Kramer thanks for the initial advice, I think I will stick with the ae200 for the moment to get a start. what do I do about connecting all this together though? do I need some hardware to connect it all? and what about cables from the pc to the projector
    ? and from the dvd to the projector?..I know this is probably real basic stuff but I`m getting real confused at the moment "overload "and dont want to buy all the wrong cables :( ie do I use a VGA cable from the pc to the ae200 and what is the best option and maximum lengths?
    thanks so much for the quick response
    drgonzo
