Oakleyspatz Prominent Member Joined Oct 9, 2004 Messages 3,708 Reaction score 236 Points 726 Age 57 Location Woking Jan 30, 2005 #1 I'm going to convert my garage into a home theatre and will be putting up a stud wall a suspended ceiling and laminate flooring. Which should I do first and why? Cheers guys.
John Moderator Joined Dec 13, 2002 Messages 14,188 Reaction score 6,310 Points 3,337 Jan 30, 2005 #2 Laminate last . Cos you dont want to damage it before you finish JS
W woody67 Established Member Joined Nov 11, 2002 Messages 634 Reaction score 13 Points 111 Location Birmingham, UK Jan 30, 2005 #3 What type of suspended ceiling? If its a propriatary one with metal grid and tiles then that will be done after the wall and before the floor finish. If its just a plastered ceiling, then it will run in with the wall but plastered before the wall is. You would do the framing first, then the cabling, then the surface boarding/plastering, then the surface finishes
Oakleyspatz Prominent Member Joined Oct 9, 2004 Messages 3,708 Reaction score 236 Points 726 Age 57 Location Woking Jan 30, 2005 #4 cheers chaps !
H hatcher Guest Jan 31, 2005 #5 Oakleyspatz, Check out my link. May find a few tips / ideas. Cheers, Ray
