Novice cable monkey need help
Discussion in 'Cables & Switches' started by snowbhoy, Sep 8, 2005.
  1. snowbhoy
    snowbhoy
    Jul 8, 2005
    126
    London
    Hi Guys,
    Wondering if I can call on your collective expertise to help a novice like me (If I'm on the wrong forum please let me know).
    So I've moved into my newly purchased house, and I've finally splashed out and bought myself a new LCD TV and home entertainment system to add to the bits I've got already and I'm about to put some floorboards in and have my tv & speakers wallmounted .. and I'm looking at all these different connectors and thinking - ok what do I use to do what?
    Can you help, I've basically bought a 32" Philips 9832 LCD, the Denon 550SD home entertainment system to add to my Xbox (Using as a media center) and my soon to arrive Sky+ box. I'm attaching all the specs below and hoping someone with knowledge in these things can suggest what I should be connecting where, what cables I should buy to do so (For best results) and any general advice really.
    Many thanks in advance for taking time to look and help me in this exciting new adventure.
    TV
    Connectivity
    Ext 1 Scart : Audio L/R, CVBS in / out, RGB
    Ext 2 Scart : Audio L/R, CVBS in / out, RGB, Y/C
    Ext 3 Scart : Audio L/R, CVBS in, CVBS in / out
    Ext 4 : S/PDIF digital coaxial, YPbPr
    Ext 5 : DVI with HDCP, YPbPr
    Ext 6 : HDMI
    Other connections : Analogue audio left / right out, SP-DIF in (coaxial), SP-DIF out (coaxial)
    Front / Side connections : 2x USB 2.0, Audio left / right in, CVBS in, Headphone out, Multi-slot memory card reader, S video in
    DVD
    Connectors
    Colour Component Output
    S Video Output
    Composite Video Output
    SCART (RGB, Composite)
    Digital Output optical / coaxial 2 / -
    Digital Output 96-kHz
    Analogue Audio Output (Stereo)
    AMp
    Digital Inputs optical / coaxial (freely assignable) 2 / 1
    Digital Outputs optical / coaxial 1 / -
    Analogue Audio inputs 4
    Analogue Audio outputs 2
    Multichannel inputs (100 kHz, DVD-Audio/SACD compatible) 6-channel (60 kHz)
    Pre-Amplifier Outputs SBR / SBL / Subwoofer
    Video Inputs Composite / S-Video 3 / 3
    Video Outputs Composite / S-Video 1+Monitor / 1+Monitor
    Video Inputs Component
    bandwidth 30 MHz
    freely assignable 2
    Video Outputs Component 1 (Monitor)
    Gold-plated Terminals Headphones
    Headphone output (3,5 mm)
    XBOX
    Sky+ Box (PACE 2 hopefully)
  2. snowbhoy
    snowbhoy
    Jul 8, 2005
    126
    London
    Anyone?
    Just a quick one para - like plug scart from DVD - TV sorta deal. Bit overwhelming for the newbie to figure out what should go where for best results.
    Apreciate any help I can get.
