spyder viewer
http://www.novatech.co.uk/novatech/prods/components/cases/mediacentrecases/novatech/nov-vision.html
The case comes well-packed in a triple-wall cardboard carton with carry-handle. It has the usual polythene bubble cheeks to protect the case. Included in the box is a carton containing the remote control, instructions and a power adaptor to enable the front-panel switch to interface to the psu. (not necessary as the mobo will take the switch connections directly). Also in the bag: tie-wraps X4 and various mobo and drive retaining screws.
The 250W matx psu comes ready-mounted, there is no mains lead provided.
There is no isolation switch fitted to the psu. The front panel has a large power button, is black anodised with a bright aluminium bezel to highlight it. There are six smaller buttons for reset, then hot buttons for My Music, My Pictures, My TV, My Videos and My Home (can't wait to find out what this does). Also there are indicators for power and HD activity. There is nothing in the instructions to indicate the operation of these buttons. There is also a window behind which, is the ir receiver with a led to indicate signal received. There is a small inset panel with aluminium highlighting mounting 2 usb sockets and the usual audio jacks. There is a hinged flap to stealth the optical drive. In the TLH corner is a Novotech logo made from plastic and is probably removeable. The case sits on 4 silvered feet with rubber inserts.
The remote has the majority of buttons on a normal windows remote with the exception of no Windows button. Interestingly it has "mouse" buttons!
The case cover and front panel are made of brushed aluminium and is black-anodised. The sleeve-style cover is held in place by 10 philips screws. The base is of anodised steel, the major edges are turned over to reduce the risk of cut fingers (nice touch). There are two stainless steel tie bars to give the case rigidity whilst the cover is removed. The mobo pillars are pre-installed and there are 2 extra in the screw bag. The drives (1 each of 5.25 and 3.5) fit to a separate sub-chassis which is held in by 2 screws. There are rubber bushes for the 3.5 drive. The psu has the usual 4 pin power plugs (4), sata power (2), floppy power , cpu and mobo (24pin). There is a rubber seal where the psu attaches to the back of the case. There are three perforated areas in the bottom of the case: under the mobo, under the drives and behind the front panel where it is pre-drilled to mount a 120mm fan (not supplied)
The pci card back panel is pre-perforated to allow the openings to be created. The flange for the pci card screws folds out and extends beyond the back panel, the edges are a little rough but not sharp, not going to be an issue once there are cards fitted and it's on a shelf against a wall.
Although there is no mention in the literature, more adventurous builders could probably install mounts for additional hard drives.
My reasons for purchasing this case apart from evaluating it is to use some components I have lying around from previous HTPC builds.
GA-G31M-ES2L motherboard
500 Gb hard drive
Radeon HD 4350 graphics card
Atheros pci-e WLAN
Peak dual DVB-T tuner
Samsung 223C dvd writer
Pentium Dual core E5800
2+2Gb DDR2 ram
Assembly was straight-forward: the open-plan case was easy to work in with the drive cage removed. Tie-wraps and self-adhesive bases were used to keep cables tidy and out of the way. The space between the psu and the drive cage was large enough to stow unused power leads in. One area where special care is needed: the various pairs of wire going to and from the front panel switches and leds etc are made from quite stiff single strand wire. This has been soldered to the leads on the back of the switches and leds. Although the solder joints are sleeved, there is little or no additional support given to the pins so care should be taken that these are not snapped off. Snapping out the pci back panel slots was a little bit fiddly but it can be made easier by inserting a philips screwdriver into the crosses stamped into the metal and levering. Also, with the lid removed there is the possiblity of the base of the case flexing so it should be supported on a hard flat surface. One of the drawbacks with black anodised finishes is that although the surface is fairly hard, it can scratch so care must be taken to avoid this. The absence of a mechanical power switch takes some getting used to as it means that the unit has to be switched off at the plug in order to remove the standby power when adding or removing cards.
All trials were done using W7HP64 and WMC. In use, the issues of prime importance are: is it noisy, does the remote work and does it look good? The psu fan is noticeable even from a metre away although it's difficult to discern from 3-4 metres, it's more fan noise than motor hum. It's quieter than my Antec Fusion which has a psu and 2 case fans in. The psu draws air in through the vent on the top of it (which is inside the body of the case) and exhausts it through the grill at the back. In my application, this is the only form of forced extraction from the case. The cpu temperature is 30 degs c and the stock cpu fan speed ~1100rpm. The remote as stated before has no Windows key so the only way to get WMC up is to switch to mouse mode and use the joy ring to move the curser. There are two buttons which emulate mouse buttons. There are dedicated buttons which select music, recorded tv, pictures, videos. The power button puts the pc into standby and wakes it up as well. The buttons on the front panel perform a similar function to those on the remote. If you have no alternative then you could get by with the supplied remote but if you have had experience of a comprehensive Windows remote it will take some getting used to. The remote feels a little a little "plasticky" and it remains to be seen if it will stand the test of time. I'm sure that my "review" team will iron out the bumps. Additional info: Initial impressions are that this remote is terrible. The ir receiver is very slow in passing the signal on to the usb port (or the usb port doesn't have a very high priority). When there is high disk/cpu activity, it can take several seconds for the received signal (receiver light flashes straight away) to be acted on. For instance: if you press the volume control you have to wait 2-5 secs for the volume "window" to appear in WMC. You then have a few seconds to adjust the volume level before the window disappears. Whilst listening to music streamed from a network drive, it was something of a lottery whether WMC would respond at all. The "chapter" buttons do not work at all. The front panel buttons (with the exception of power) are flush, the optical drive stealth flap partially obscures the button when the drive is open but as I'm happy to just nudge the tray so had no problem with it. There is a green and a red led for power and HD activity.
The large Novotech logo tends to dominate the overall appearance which is otherwise good. Bearing in mind observations already made, £50 for case, psu and remote: I have no hesitation in recommending this case as a value for money choice for a HTPC/PVR.
500 Gb hard drive
Atheros pci-e WLAN
2+2Gb DDR2 ram
