Novatech 30" Widescreen LCD - £680
Discussion in 'Shopping, Deals, Discounts & Bargains' started by Baloo, May 20, 2005.
  1. Baloo
    Baloo
    Aug 22, 2003
    767
    28
    Bath
    +33
    Looks quite nice at the price.
    Spec :-
    Panel Size 29.6" (75,2 cm) CMO Panel
    Viewable Size 649 mm x 392 mm
    Aspect Ratio 15:9
    Resolution 1280 x 768 (WXGA)
    Pixel Pitch 0,5025 mm
    Colours max. 16,7 Mio.
    Contrast Ratio typ. 600:1
    Brightness typ. 550 cd/m²
    Response Time 16 ms
    Viewing Angle H/V 170°/170°
    Video Systems NTSC / PAL / SECAM
    Power Consumption max. < 180 Watt / Stand-By Mode: < 5 Watt
    Power Supply AC 100-240V / 2A
    Cable Tuner (Hyperband) Auto/Fine Programming HDTV (1080i) Progressive Scan, PIP-Function (Picture-in-Picture)
    99 Programme Memory TV, Teletext (10 pages)
    Speakers 2x 8 Watt
    User Control OSD
    Wallmountable VESA 100 x 200 mm
    Video Inputs Antenna, VGA, Scart in (RGB in, CVBS), Scart out (TV out), S-Video, Composite,
    Component YUV (Y/Pb/Pr)
    Audio In- and Outputs Composite, S-Video, Component, PC Audio / Headphones, Audio, Sub-Woofer
    Supply User Manual, Remote Control, Batteries, Power Cord
    Weight net/gross 22 kg / 27 kg
    Dimensions WxHxD 887 x 538 x 205 mm with stand / 887 x 479 x 102 mm without stand
    Warranty 2 years Pick-Up Service
    http://www.novatech.co.uk/NOVATECH/specpage.html?NOV-LCD30
  2. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    Looks like it's the Video7 LTV30C.
  3. AndyFov
    AndyFov
    Nov 20, 2002
    1,472
    March, Cambs
    +45
  4. ScoobyZ
    ScoobyZ
    Sep 29, 2003
    1,004
    +82
    Guys dont do it. I used to work there at Novapoo, it will be the cheapest they can import and will be a job lot that they wont support after a while.
