Notting Hill R3
Discussion in 'Movie Forum' started by damolong, Aug 15, 2002.
  1. damolong
    damolong
    May 15, 2002
    73
    I've bought this from CD Wow for £5.74. However, after a quick play this morning before work, it has Mandarin subtitles for which I can't see a menu option to switch off.
    Any ideas?
  2. mikey
    mikey
    You could try the subtitles button on your remote, if you have one - a subtitles button that is, not a remote! Failing that there is a menu option on the disk, I found it when I bought the same disk from CD WOW. The other thing I seem to remember is that the introduction titles to the film is translated via what appears to be subtitles which go by the time the real dialogue starts. Click on a few chapters and check again.
  3. damolong
    damolong
    May 15, 2002
    73
    Cheers Mikey - just going home so will try later tonight!
