Noticed something strange on my screen
Discussion in 'General TV Discussions Forum' started by Dom H, Feb 5, 2003.
  1. Dom H
    Dom H
    I have a Pansonic PL1 32" and have recently noticed an oily 'pattern' all over the screen when looking at reflections. I've never used anything on the screen only a dry cloth to wipe the dust off. I dont think it's on the outside as I can't remove it. The set is only about 6 months old, any ideas?
  2. andyw
    andyw
    You get this on PC monitors and it is normally the protective layer above the glass. Use a good glass cleaning product and only use a paper towel to dry. You should find that the 'oily pattern' will disappear.
    andyw
  3. Dom H
    Dom H
    if it's supposed to be there shouldnt i leave it
  4. andyw
    andyw
    What i meant was that it isn't a permanent coating, it does wear off. Normally fag smoke makes it look worse than it is. You won't do any damage by using a good quality glass cleaner or wipes made for cleaning PC monitors.
    andyw
