Not sure what this means?
Stream62
Hi, i'm after some very cheap interim speakers to go with an AV reciever I am planning to buy. I will eventually upgrade to some decent ones once I save up some money. The av reciever (sony dg820) needs a 8ohm speakers my current ones are 4ohm.
I have found some undoubtly rubbish ones on ebuyer for £27 however as a short term fix they would do nicely for me.
http://www.ebuyer.com/product/126454
The description shows
  • 3"8Ω10W(mediant)
  • 1.5"4Ω5W(treble)
I have no idea what this means, can anyone help/let me know whether they will work for me?
Badger0-0
They'll work no problem :smashin:
Just don't turn them up too much, as the amp could possibly blow them.
If it sounds distorted, it's too much volume ;)
Stream62
Thanks Badger. The room is pretty small and it will only be a short term solution anyway.
I take it that the mediant is the number to look at then?
Badger0-0
"Mediant" is a totally new one to me, when describing speakers :confused:
Which suggests they are pretty crap, as you say yourself.
I wouldn't worry about it though, as long as you take notice of my previous post :smashin:
They'll do a short term job.
The important thing is, you're not going to blow the amp :)
