Hello
Ive had a HD box installed in my living room and that was october time i told the chap when i get heavy rain i loose the signal all together all channels go he hooked it up to his black box and said it was under so when its bad weather i will loose the signal,He then went outside and adjusted the skew on the lnb that seemed to do the job as we had some bad rain in october and no more loosing channels
As the signal problem had gone i decided to go multiroom.
I have now had a second box put in the bedroom by a different installer in november but since wednesday i have noticed a get very slight pixelation go across the screen at first i thought great its raining so thats why,But it happens when there is no rain but not all the time and it only happens on one channel the disney channel,As im still in the month time limit i phoned the installer he came out and checked the bedroom connection with his box and said it is under a bit because the dish is in line with a big tree,He didn't go to the dish to see if it has been moved by the wind which we have had badly,He just said its the tree thats causing it.
The thing is ive never had this problem before he fitted the multiroom box.
Ive had problems with this installer before when i had to have him out a couple of years ago i lost some channels he then told me it was the trees i wasn't having what he said so i complained to sky and another chap came out and replaced the dish and cable and would you belive it all the channels came back.
If it was the tree would it just cause pixelation on one channel when there is no wind rain etc...
