Not sure of this is a Tosh XS32 issue or TV issue
Discussion in 'Blu-ray & DVD Players & Recorders' started by nunew33, Sep 1, 2004.
  1. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    When I switch to the Tosh the TV audio level is much higher than other sources to the extent that if i forget to lower the volume I get minor heartattacks when changing channel.
    Is there an audio out setting that I have missed? Is it something not settable.
    the TV is a bulk standard sony 29 inch 4:3 about 7 years old
  2. Bob H2
    Bob H2
    Aug 27, 2004
    34
    I have the exact opposite problem. When I switch to the Tosh, the volume goes down.
    I believe it to be a TV issue.
  3. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    I get the "higher" volume on my Panasonic when switching on.
    I think it is a TV issue, I have set the volume offset to full on my AV sources but probably haven't set it that way for terrestrial.
  4. GoldFish
    GoldFish
    Nov 4, 2002
    97
    9
    Bradford
    There is no audio output level setting on the Tosh, but have a look at the user manual P161, you should be able to attenuate/boost the various inputs to match.
    One of my output is also connected to a 6 yrs old 29inch 4:3 TV (cannot remember the model number) and the user OSD on the Sony do allow input audio level adjustment to match the various source...
    HTH
