not receiving incoming calls
Discussion in 'Mobile Phones Forum' started by brandy123, Mar 4, 2013.
Tags:
  1. brandy123
    brandy123
    Jul 4, 2009
    1,860
    +107
    Hi I have had a s3 for about 3 weeks now and every now and again some people ring me but can't get through to me and they tell me its not even ringing I would say this happens about once a day but the way around it is if I ring out from my s3 it somehow kick starts my incoming connection for awhile I have checked the call settings plus I have received a new sim card from Vodafone but still the same problem any suggestions what it could be? Is it best to return the device and try another one
    I have even reset to factory state yesterday and my mate has just texted me to say I can't ring you
  2. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
    Do you notice this problem in one location only or is it network wide?
    Is your phone connected via GSM or 3g when you have problems? You could try changing the network mode to GSM only or wcdma only. Obviously changing to GSM only will have a huge difference on data speeds.
  3. brandy123
    brandy123
    Jul 4, 2009
    1,860
    +107
    Hi sorry for the late reply I only notice the problem in my house as when I am outside I am usually with the people who ring me anyway, I did exchange the phone today and I still get the problem, I have checked the network mode (I think that what's it called) and that is set to auto gsm/WCdma
    Any other ideas
  4. stunno
    stunno
    Apr 8, 2007
    951
    96
    +612
    You're not on EE are you?
  5. brandy123
    brandy123
    Jul 4, 2009
    1,860
    +107
    No i am on vodafone, just waiting for the problem to start again and trying changing to 2g as i will be at home and to see if that helps as i will be useing my wifi at home then switching back on 3g when outside worth a try ?
  6. stunno
    stunno
    Apr 8, 2007
    951
    96
    +612
    I'm on EE and for a few weeks now, I'm not getting calls, data or SMS until I toggle the signal from GSM to gsm/wccdma . I've even installed a 2G/3G toggle on my desktop to make it easier!
    I usually need to change at least 3 or 4 times a day, but sometimes ahve to toggle half a dozen times, one after another until it connects. It's VERY irritating!!
  7. sep8001
    sep8001
    May 2, 2008
    2,647
    103
    +280
    Did you get this sorted out? I seem to have the same issue on my one with is with ee.
  8. brandy123
    brandy123
    Jul 4, 2009
    1,860
    +107
    Hi I am on Vodafone and since I started this thread I to installed a 2g/3g toggle and I have left my s3 on 2g and I have always received calls plus I popped into my Vodafone shop and have been told they are working on the 4g signals around where I live but my downside on this is data is very slow regarding going online via 2g
    Sent from my GT-I9300 using Tapatalk 2
  9. andrenasey
    andrenasey
    May 16, 2013
    72
    11
    +5
    there might be many problems solution might be.....
    1. Restart the phone.
    2. Enable flight mode and disable so that it reconnects.
    3. Make an outgoing call and a flood of missed text messages will come in (strange!)
    OR
    You could try clearing the data and cache in the phone app..
    Main settings/Application Manager.
