Not quite 37" PW7
Discussion in 'Plasma TVs Forum' started by David, Dec 12, 2004.
  1. David
    David
    Nov 26, 2002
    221
    16
    London
    I've got a border of about half an inch of unused screen all around the picture on my TH37PW7B. Anyone know if this is normal or is there a way of expanding the image to use the full screen?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    its just the under/over scan needs adjusting get a 16:9 DVD and use that, you need a known image dimension to adjust this a caopy of DVE PAL would help...
  3. David
    David
    Nov 26, 2002
    221
    16
    London
    Not sure what DVE Pal is I'm afraid. The border is on all sources as far as I can remember and true when the picture is in 16:9, Zoom or Just aspects. It's also about an inch at each side and half an inch top and bottom.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    its a calibration disc with test patterns have a search for "DVE" also you can do it by eye........ use the size Position button for adjustment
  5. David
    David
    Nov 26, 2002
    221
    16
    London
    Thanks, I'll give it a go.
