Not Outputing Dolby Digital on Pioneer AX5i
Discussion in 'AV Receivers & Amplifiers' started by Anuj, May 28, 2004.
Tags:
  1. Anuj
    Anuj
    I've got a Pioneer DV-757Ai DVD player, Sky+ and a Pioneer AX5i amplifier. Both are sending Dolby Digital Signals, the DVD player through FireWire and the Sky+ through SPDIF (optical). The amplifier indicates that it is receiving a Dolby Digital signal, however, all the sound is going to Left and Righ Front speakers, and subwoofer. The Center, Rear Right and Rear Left speakers are not giving out any sound. I went to the speaker setup that the amplifier has built-in and it sent out seperate signals to each speaker including the other three that usually do nothing, and everything worked fine. What's wrong?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Although the receiver is receiving a DD signal it wont output it if the receiver is in stereo etc mode. Have you set it to output DD?
    Mark.
  3. Zone
    Zone
    Jun 24, 2001
    6,563
    Barnsley
    +2,179
    Exactly as Mark says.
    I sometimes put a film on after my youngest lad (4yrs going on....ooh just too smart for his own good :mad: ) has been having a mess without me knowing and I end up with the same problem :censored:
  4. Anuj
    Anuj
    So how do I set it to DD on this amp? The instructions are kind of useless :lease:
  5. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
    Press MOVIE on the remote, use the arrow keys to select the format you want and press ENTER.
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Also from the DVD menu select the audio setup option and select it to output DD. This can normally be done on the players menus or from the menu on tha actual disks.
    Mark.
  7. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    I fell into a similar pitfall when I set up my AX5i/757Ai.
    Even though you're using i-link, you need to go into the 757's menu and tell it it's connected via 5.1 leads, if you don't do this the 757 will only output a 2 channel DD bitstream, which is what your amp is picking up.
    This is where you're going wrong, done it myself!
    PS have a look in the 757 manual, it's in there with a bit of searching.
  8. Anuj
    Anuj
    Yep, pressed Movie and everything works fine now. Thanks.
