Not getting DTS from mobo SPDIF ?
Discussion in 'Computer Components' started by Spysmys, Jan 20, 2008.
  1. Spysmys
    Spysmys
    Aug 31, 2007
    47
    11
    When I run the sound setup in control panel I can get DTS to work, but playing a BR disc on Power DVD I get 2 channel audio ? any suggestion how I can change the settings ?
    Spys
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    What version of Power DVD do you have as that does make a difference.
  3. Spysmys
    Spysmys
    Aug 31, 2007
    47
    11
    Version 7.3 ?
  4. tinners
    tinners
    May 22, 2006
    3,288
    Bucks
    +242
    You need to go into setup when you are NOT playing anything and select the SPDIF option in PDVD setup menu.
  5. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Adding to tinners post, make sure your sound card/mobo drivers are defaulting to spdif and your sound option in control panel is also set to spdif. :)
  6. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    If it's the one that came with your drive then I *think* that one does only do channel audio and you need to upgrade to the full version of PowerDVD to get what you want.
  7. tinners
    tinners
    May 22, 2006
    3,288
    Bucks
    +242
    I read that somewhere too.
