Rupert123
I would really appreciate a bit of help.
I have been trying to figure out why I can’t get a 4K output to my TV from my Xbox one S after connecting to my Arcam receiver using an HDMI input. I recently bought the Arcam avr 850 from eBay and trying to set up my home cinema. Plans are to connect all inputs from sky, Xbox, Apple TV via HDMI to Arcam and use one of the outputs to my tv and the other to my pj.
My sky Q box , however, when connected to the Arcam input seems to be able to output a 4K signal to my TV via the Arcam HDMI output. My TV is 4K capable, but my Xbox using the same HDMI output from Arcam to my tv is only transmitting a 1080p signal.( the 4K option is greyed out in my xbox settings and message from Xbox states that my tv does not support 4K).
I would like to use the second HDMI output from Arcam to output a 4K signal to my pj. But I am struggling to get a 4K image even to my TV from my Xbox one S. When I unhooked the HDMI cable ( connecting tv and Arcam output) from the Arcam Output hdmi slot and directly connected to the Xbox I get a 4K output on my TV. I am sure that arcam avr 850 is capable of processing a 4K signal and demonstrates this by outputting a 4K signal from the Sky Q box, so I don’t get why the Xbox isn’t doing the same!
Any advice will be highly appreciate.
thanks,
Rupert
thanks,
Rupert
