Not enough space on sky+ - what's best option?
Discussion in 'Digital TV & Video Players & Recorders' started by Triggaaar, Jul 20, 2004.
Tags:
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    20 hours is just not enough, so I'm wanting to know the best option for adding more storage. I've never used any of the following, except std sky+, so I'm not too sure of the pros and cons, but will put down my assumptions.
    I don't HAVE to have long term backup (dvd), but do need more than 20 hours.
    Note - my sky+ is SDI modded, so output to anything else, then to video processor, will not be as good as watching direct from sky+
    1) Put larger disk in
    pros - no extra boxes, no extra loss of quality, easy to use, records in DD5.1?
    cons - reliability issues, still fairly limited space
    2) Use a DVD recorder
    pros - unlimited storage, presumably fairly easy to use
    cons - lose some quality? An extra box, lose DD5.1
    3) DVD recorder with HD
    - as above, but with editing facility
    - not sure if HD quality is different from DVD
    4) Another HD box with larger disk (Tivo or something)?
    pros & cons - I'm not sure yet, will do some searching
    EDIT - forgot to mention:
    5) Link SDI output of Sky+ to SDI capture card in PC
    pros - lots of storage space, editing software, can copy to DVD
    cons - constant software issues that need keeping in check
    Any suggestions?
  2. sparkybun
    sparkybun
    Jan 6, 2002
    1,237
    41
    EN8 area
    +23
    http://www.hummer.co.uk/
    The 120Gb upgrade looks the most common and easy option on a V1 Box.
    Look for the sticky on the upgrade as well in the SKY+ Threads.
    Cheers and Good Luck
    Mel
