Not enough connections...
Discussion in 'General Video Gaming Chat' started by john87, Apr 26, 2002.
  1. john87
    john87
    I have to connect three consoles plus an indoor aerial to my t.v. but only one aerial connection meaning anytime I want to watch t.v., switch console etc. I have to change the connection... it's also very hard to get behind the t.v. as well... so...
    Is there any way of getting round this?
    Cheers :)
  2. john87
    john87
    There must be a way....
  3. john87
    john87
  4. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    Assuming that you've got no scart connectivity or any phono (composite) options, can't you get some sort of 2- or 3-into-1 lead for the aerial connection?
    EffTee
  5. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    Your Bush TV doesn't have Scarts?????????
  6. john87
    john87
    Yes, two.
    One used for DVD.
    One used for X-Box.
  7. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    In that case, I can recommend the Quattro+ Scart Controller. It has three RGB Scart, one S-Video Scart input and a normal S-Video input. There is no degradation in signal using the box. I have my PS2, DC and XBOX linked through mine and I wouldn't be without it.
  8. john87
    john87
    Where can I buy it? How much is it?
  9. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
  10. john87
    john87
    :eek: A bit pricey?!?
    That's a rip off in my mind. Oh well.
  11. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    It was worth it as far as I was concerned. I have three consoles that need RGB connections but only one RGB Scart. I was sick of going behind the tv to change them over. I tried a cheap Scart splitter but it degraded the signal. This works perfectly but I can understand that you think it's expensive.
