Not enough connections
Discussion in 'Xbox Forums' started by andyb_68, Mar 28, 2006.
  1. andyb_68
    andyb_68
    Mar 27, 2006
    169
    Oxford
    OK, I have purchased the 360, love it. But now I need the HD LCD, I knwo the 360 has component connection but so does my DVD (if I want to use progressive scan) So how the hell will I be able to connect both units, I dont want to use the 360 has the DVD player because of the noise.
    Any suggestions as most TV's only have 1 component connection.
  2. buba
    buba
    Dec 14, 2002
    118
    +5
    Just posted a similar problem Andy:(
    Have you got a amp?
    I got around it buy using my amp as a switching box! I have 2x component inputs and a component out at the back of your amp??
    DVD and xbox360 go to the inputs and out goes to the projector.
    I now want to get my 360 signal to a LCD TV aswell:rolleyes:
  3. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    You can also buy a few different component switch boxes. Here's a couple of the forums favourites, here and here. Obviously price comes into it, you pays your money, you makes your choice :D
  4. DarkEntity
    DarkEntity
    Feb 13, 2005
    2,581
    2
    137
    Glasgow
    +603
    Why are you posting this in the 360 section?
    your lack of connections on the TV and other equipment is hardly a 360 console problem.
    Id suggest you get a component switcher box if you desperately need component on both.
  5. buba
    buba
    Dec 14, 2002
    118
    +5
    easy tiger;)
    he has has a problem with connecting up his Xbox360! so he posted here:rolleyes:
    I am sure lots of people have had the same problem!
  6. andyb_68
    andyb_68
    Mar 27, 2006
    169
    Oxford
    Thanks for the replys, even the up tight one!
  7. andyb_68
    andyb_68
    Mar 27, 2006
    169
    Oxford
    thanks, that is why I did post here, The answers have been very helpfull, Why the hell did micrisoft not have HDMI. Oppps should that go under "connectors" forum
  8. buba
    buba
    Dec 14, 2002
    118
    +5
  9. Quiznite
    Quiznite
    Aug 11, 2005
    214
    Hull
    +6
    I use this one 3 way switcher above and have got
    Xbox
    DVD
    and 360 going into PV500 and even thought the box is £14 quid the picture is stunning !
    I have mark grant componenets from dvd player and using this inline doe's not eefect pic.
  10. nick501
    nick501
    May 6, 2005
    7,217
    Walsall, West Midlands
    +782
  11. Binternet
    Binternet
    Oct 30, 2004
    190
    Sunderland/Newcastle
    If your TV has a VGA input you could buy the 360 VGA cable and let the DVD use the components. That is what I am currently doing and the VGA picture is a lot cleaner than components, although the colours do take some getting used to.
  12. andyb_68
    andyb_68
    Mar 27, 2006
    169
    Oxford
    once again thanks very much for the answers,
  13. NackNack
    NackNack
    Aug 28, 2005
    3,562
    68
    Northampton
    +97
    Why did you not buy a HDMI DVD player? :p
    They didn't do HDMI because of cost, and it offers no advantage over component for them.
  14. amflemi
    amflemi
    Mar 7, 2006
    118
    +15
