Not enough component inputs?
Discussion in 'Plasma TVs Forum' started by Stampax, Aug 12, 2005.
  1. Stampax
    Stampax
    May 6, 2005
    1,377
    Northampton
    +85
    What do I need to buy in order to hook up two component signals into a TV (37V500) with only one component input?
  2. dodgyd
    dodgyd
    Jul 8, 2005
    841
    +72
    Check that your AV amp (if you have one) has component switching built in. I was surprised to find that mine does on checking it a couple of weeks ago.
    (dodgy from thedvdforums by the way, hello :) )
    Dave.
  3. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,516
    Kent
    +830
    JS Technology have what you need!! 2:1 auto sensing component switch £55. Bargain!!
  4. Stampax
    Stampax
    May 6, 2005
    1,377
    Northampton
    +85
    No my amp doesnt have component switching.
    55 quid! blimey! Having just shelved out for the plasma, dont think I fancy that!!!! I was hoping for a cheaper alternative!
  5. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,516
    Kent
    +830
    Wow you must be doing this on a budget!! You could probably save a tenner or so and go with some "Argoos" stylee mechanical switch. But it will intefere with the signal far more than the JS box so would be a bit of a backwards step choking the PQ after having spent so much on the screen.
    I know what you mean though, once you've forked out the big number on the plasma itself you're loathed to spend the extra 10 or 20% on accessories & cables required to actually get the thing running optimally!!
  6. Stampax
    Stampax
    May 6, 2005
    1,377
    Northampton
    +85
    Well it was the xbox that was going to require the other component input, but considering i also have to buy the hi def kit for this as well, it really does start adding up, as i have to buy lomger cables for everything i own as am wall hanging the plasma. Really dont want to spend hundreds on cabling - i think the wife will shoot me!
  7. xprezz
    xprezz
    I feel your pain stampax. Ordered my PV500 a couple of days ago, then high-def kit for xbox. Now I am looking into an amp with component switching and a new HTPC.. I should never have started this project :)
