Not Again
Discussion in 'AV Receivers & Amplifiers' started by wallzy, Feb 28, 2005.
  1. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    As some of you might remember i brought a denon avr2105 and it blew up
    (see here) the shop were i brought the amp from replaced it with another denon avr 2105 i set the amp up again all was going fine the amp is not a week old yet and the same has happened again i had a cd playing at around -22db's the music cut off, i let the amp cool down turned the amp back on there was a flash and a sound of sizzling from inside the amp now the same is happening that was happening to the other amp.
    does any one know why this might be happening again i have checked all the wiring nothing seems to be touching. i dont think that -22db's is extremly loud (or is it) i dont feel i was pushing the amp all that much my old amp a sony str-de585 seemed to handle these volumes and more with ease so i thought upgrading to a amp with more output would have been able to handle them :oops:
    Also could anyone recomend any other amps for around £500 (that isnt what i paid for the 2105 just have a bit more money spare) that arnt going to keep blowing up. the amp will be used for 50/50 music and movie i also like the 5 channel stereo sound feature for audio any recomendations
    thanks in advance
    Dean Walls
  2. GFS AV
    GFS AV
    Jan 28, 2005
    429
    16
    Look at the Yamaha range of amps. I would say the nearest to the 2105 is the DSP-AX750SE. I have the older 640SE and it has been a great amplifier. The build and reliability of Yamaha amps is second to none. From what I have read, the 750SE is very good with music too.
  3. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I would check your power supply first, two amps blowing up isn't a good sign, you could be having a very unstable power supply and due to the high current draw of your amp it may not be able to provide a stable supply.
    Are you using any form of surge protection? This should help in the first instance, you may need some form of power regulator. I'm no electrician or physicist, so maybe others will have more info.
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,810
    London
    +1,082
    Agree with Kaz, 2 amps blowing sup sounds like more than coincidence to me.
  5. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  6. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    Is it well ventilated with plenty of space around and above it?
  7. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    i do have a surge protecter but there is quite a lot that is plugged into the 2 sockets that are in my room it is well ventilated around and above the unit its on the top shelf of my AV rack so plenty of room abvove and there is around a foot of space behind
    could any one with one of these amps tell me what there normal listning level is on the amp have they had any problems listening to the amp at that level
    thanks
    Dean
  8. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    -22 is safe on almost any amp, so that wouldn't be the problem, unless your speakers are INCREDIBLY difficult to drive (even then it is unlikely this would cause your problem after such a short time).
    The only two explanations I can think of are:
    1: Bad batch of amps received by your dealer.
    2: Bad power supply being fed into the unit.
    Might be an idea to contact Denon to see if they are aware of any bad batches causing this problem. Also, make sure you have the correct voltage set at the back of the amp, 220V for UK/Ireland and 110 for USA (athough this is clutching at straws).
  9. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    Thanks to you all for replying
    Kazman you saying it might be a bad batch has just made me think when we returned the other amp the sales person was making note of the serial number and he said that it was only 3-4 up in serial numbers so may be they are from the same batch i think i will be looking into the power supply issue the trouble is my plug sockets are across the room from all my equpiment so there is 2 leads run around the room then it plugged into one of these leads (both with breakers on)
    thanks Dean
  10. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    Just taken the amp back to the shop and returned the amp they was sayin it could be a problem with the speakers that i am using,then some one from another shop said they had 2 of the same amps returned with a identical problem so it looks like it is a problem with the batch
    thanks Dean Walls
  11. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    No probs
    Looks like a dodgybatch is definitely the cause then. You going to stick with the same amp model or try a different brand?
    If you are going to try something different, I'd reccomend the Marantz SR7500, the Pioneer 1014i and the Yamaha RXV1500
  12. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    i was looking at a differnt manufactoter next although the denon was a good amp the 2 going pop on me has kinda put me off a bit dont really want to risk another one i was looking at the Pioneer 1014i there is just a few questions that i will be asking about this amp before i comite to buying
    thanks
    Dean
  13. wishy
    wishy
    Jan 23, 2005
    105
    19
    Boldon, Newcastle, England
    I too have had an AVR 2105 cut out problem. I too was listening at moderate levels, well ventilated and the cutout occurred only after 5 mins play. Not too much to ask I think.
    The amp is less than 6 months old and powering MordauntShort premier plus 5.1 speaker system, all wiring looks fine and dandy.
    I was wondering if anyone has contacted Denon as regards the bad batch issue.
    My serial number on the Amp is; 4073300296. anyone have their dodgy amp serial number handy! How about you wallzy
    :lease:
  14. OldSkoO1
    OldSkoO1
    Nov 27, 2004
    565
    28
    +29
    i would also be concerned about loading 2 plugs with lots of stuff. I'm not saying its the cause of the problem but it is potentially dangerous to load too much stuff onto the one socket.
    hope you get it sorted out
    GL
  15. Arif
    Arif
    Feb 13, 2004
    94
    Northampton
    I'd completely second this, Wallzy dude.
    I've just gone up from the 640 to the 757 - cos they're just so good.
    On the Yamaha DSPAX640SE I regularly leave music blasting throughout the house, via the 5.1 set-up - on say -10dB or more - for hours on end - and all one ever knew was the little fan in the amp kicking in - and then only after about an hour or so of severe exertion. Awesome - I highly recommend this line-up of amps.
    P.s. Though - it is worth checking (for all future cases) your speaker impedance settings. This one is just so easily overlooked - and can well lead to over-load problems, if the settings aren't matched. If your speakers say that they're 8Ohms, then you're pretty much gonna be okay - as this would be the default setting on most amps.
    Good luck!! And if you get the Yammy - let it rip and have fun with no stressing about stressing it!! (P.s. I got my DSPAX757SE from AVLAND (guy there is called Kingsley) for £399 - price-matching Richer Sounds)
  16. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,547
    7
    167
    Birmingham, UK
    +10,376
    Unless I've missed it, why has nobody asked you about your speakers?
    Are you correctly matching the impedance? What speakers have you got?
  17. wishy
    wishy
    Jan 23, 2005
    105
    19
    I'm very new to the "AV world" Stuart but on refering to the Denon 2105 manual it refers to 4~16 ohms impedence.
    My speakers are all labelled 80w 4~8 ohms. (Centre, 2front and 2surround). Plus subwoofer
    So am I right in thinking that Mordauntshort 5.1 premier plus setup should run ok on the denon amp.
    Considering the sound level is neva cranked up, due to the wee ones!! ;)
  18. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,664
    Premiere's are not the easiest speakers in the world to drive but I don't have any other cases where this has happened. A cable short could do this however.
  19. wishy
    wishy
    Jan 23, 2005
    105
    19
    If I can't see anything wrong with the speaker cable connections does this mean that a speaker has given up the ghost somehow, which are under warranty, or the amp has packed up.
    If mine was one of the "dodgy serial number batch", as stated as a possibility by wallzy, I am happy to accept the amp is kaput but thankfully under warranty.
    If it is a speaker would it be one or all and how could I troubleshoot to ascertain the damaged culprit or culprits.
    Thanks for all the help so far guys!
