Not able to pause sky channels
mncollyer
I can not pause any of the subscription channels HD or SD but can pause BBC1 etc, has anybody experienced this before.
I have rebooted the box but it made no difference.
I have also started to experience some failed recordings fairly regularly in the last couple of weeks.
Thanks Mark :lease:
logiciel
Make and model number of receiver?
peebee
Established Member
When this last happened to me it was because the EPG was showing no signal on the 2nd input. A reboot sorted it out. Next time it happens check your input levels before rebooting.
PB
mncollyer
O/P, is your box in its original state or have you modified it (specifically new hard disk or power supply) in any way?
I have not modified the box it was replaced about 18/20 months ago when I was getting alot of failed recordings.
Mark
mncollyer
PB
I will keep an eye on the signal strengths
Mark
J
JezPX
I used to have a similar problem with my Sky+HD Box and the only way to resolve it was a reboot, for some reason I have not had the problem since (touch wood), but I agree that you should also keep an eye on your signal strengths.
Jez
Is 8K TV dead? Philips OLED+907, Pioneer LX505 AVR plus B&W 700 S3 Reviews & Visit + AV/HiFi News
