Not 100% certain but....
Discussion in 'Projectors, Screens & Video Processors' started by Grimley, Aug 27, 2004.
  1. Grimley
    Grimley
    Sep 19, 2003
    983
    4
    2
    47
    Deepest, Darkest Essex, so BEWARE!
    +171
    ...I think my PT-AE 300 has got a dead pixel.
    Its a really small green dot near the centre & it only shows up when certain colours are being displayed. IMO I thought a dead pixel would be a tad bigger
    that's why I'm not certain.
    I've tested it using my PC (Paint program, various colours) & other dots show up too (not as bright though) Could this be down to dust on the lens?
    I've only had the PJ since Feb this year & I want to be certain its a dead pixel before I contact the retailer & ask them what they can do about it
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Sounds like a dead pixel - it should be a bright point, rather than a "blob" which normally indicates a dust problem. There should be a Service Menu mode on the AE300 with the ability to display test screens of solid Red, Green and Blue - a dead pixel should show up best here.
    Sean.
  3. Grimley
    Grimley
    Sep 19, 2003
    983
    4
    2
    47
    +171
    Anyone know how to access the Service menu on the AE300? 'Cos I don't...
