Norton script blocking
Discussion in 'Desktop & Laptop Computers Forum' started by HMHB, Nov 1, 2003.
  1. HMHB
    HMHB
    Nov 11, 2001
    26,424
    Nottinghamshire
    +5,059
    I have Norton script blocking enabled but have just noticed in msconfig services it says "stopped" in the status column. It is ticked so it should be running.
    Can someone else have a look in msconfig services to see what it says for script blocking please as it's confusing me.
    I'm running XP Professional.
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,433
    7
    167
    Birmingham, UK
    +10,138
    What scripts does it block and are you sure you want to block them?
  3. HMHB
    HMHB
    Nov 11, 2001
    26,424
    Nottinghamshire
    +5,059
    To be honest I'm not sure ! I was thinking that it would maybe spot potentially harmful scripts on a web page
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I don't have Norton so don't have the service, but have you check it's entry in the Services list of Computer Management to make sure it's set to start at boot time?
  5. MikeTV
    MikeTV
    Feb 1, 2003
    7,781
    Ealing, London
    +842
    Mine is stopped in MSConfig too, even though I have it enabled in Norton. I shouldn't worry about it too much. I disable it in Norton usually, but that is personal choice. I always obtain the latest critical updates, perform occasional Norton scans and enable internet firewall protection.
    I am using XP Pro.
  6. HMHB
    HMHB
    Nov 11, 2001
    26,424
    Nottinghamshire
    +5,059
    OK mate cheers for that. I think it must be the normal setting then.
