normal interconnect cables vs subwoofer cables
Discussion in 'Cables & Switches' started by bbanduser, Apr 6, 2005.
  1. bbanduser
    bbanduser
    Nov 22, 2002
    1,786
    38
    Watford
    +3
    Hi guys,
    Need your help desperately on this one - are there any differences between normal stereo interconnect cables and subwoofer cables?
    To put it into context, can I use a normal stereo interconnect to connect my processor to my sub? Alternatively can I use a sub cable like the IXOS XFA01 http://www.audiovisiononline.co.uk/...ixos+xfa01+3m&meta=cr%3DcountryUK%7CcountryGB
    to connect my processor to my centre speaker? If there are differences, what are the pros and cons in going with either option?
    Thanks for all your help. The cable industry seems it's there to confuse rather than clarify!
  2. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    These interconnects are all the same (barring length and the fact that sub cables are usually single, rather than a stereo pair)
    I assume when you say "to connect my processor to my centre speaker?", that you mean connecting your processors centre speaker phono output to the centre speaker phono input on your amp, rather than connecting to the centre speaker itself :)
    I wonder why that is!!! :)
  3. bbanduser
    bbanduser
    Nov 22, 2002
    1,786
    38
    Watford
    +3
    Thanks Mike. You are right about the processor-amp connection of course. Just wrote it down wrong!
