Normal Amp Heat
Discussion in 'AV Receivers & Amplifiers' started by kryten22uk, Mar 24, 2006.
  1. kryten22uk
    kryten22uk
    Feb 4, 2005
    441
    28
    +32
    My amp (denon 1906) when on, is really quite hot. If I put my hand on the top, after about 5 secs its nearly too hot to continue. Is this normal or is there something wrong?
    Its in a cabinet which has a door on the front, but has a decent size hole in the back for all the wires, hence that its the ventilation.
  2. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    My Arcam AVR200 gets rather warm too but you could comfortably leave your hand on the thing, it just seems rather warm for a box under the tv. I could understand it if the thing has been blasting for half a day but just running the pre-outs for the fronts at the mo and still seems jolly warm.
    Kryten you could leave the door open and/or take the back out the cupboard just to see if the extra ventilation helps in any way, mind you it probably has a safety cut out which trips if it thinks its getting too warm......?
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Denon specify 10cm above and either side don't they? Less than that and you may want to consider an 'open door' policy during heavy use.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,752
    The Borders
    +3,519
    Hello kryten22uk
    Anything getting that hot has a problem.
    I'd recommend you unplug it ASAP and take it to your Dealer or local Denon Service Centre.
    Best regards
    Joe
