Norm Dial ?
Discussion in 'AV Receivers & Amplifiers' started by Jeff, May 28, 2002.
  1. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    When my Avc-A1SE flashes up Norm Dial +4 on the display what does it mean?
    Jeff
  2. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    At a guess it's telling you the metadata on a Dolby Digital DVD is telling the decoder the 'dialnorm' setting should be +4dB above unity.
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Yes, I did a little research so I understand how this works now (I think :) ) Problem is my HTPC appears to not always do this so the DVD ends up playing 4 dbs lower volume. Its a bit unnerving when the same reference DVD sounds nice and loud one day and then goes a bit quite the next.
  4. Neil Porter
    Neil Porter
    Sep 4, 2002
    103
    Ipswich
    I too am getting this message on my Pioneer VSX-D2011:
    "DIAL.NORM+4"
    It consistently does it on specific disks but there's nothing in the manual about it (unless it's hidden away in a small font;) ).
    It makes sense that it is doing something to keep the volume levels consistent across disks.
